ProjeQtOr free project management software - Recipient layout - ProjeQtOr
Recipient layout
14 Nov 2016 14:14 #1 by antonio.grr
Recipient layout was created by antonio.grr
In Recipent model the $_layout contains the line
<th field="bankName" width="25%">${bank}</th>
The recipient table instead has the column bankName. The table ColumnSelector has a row with attribute = 'bank', so the select query fails creating log lines like those :
2016-11-14 11:54:48.285 ***** ERROR ***** Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERROR: column pqo_recipient.bank does not exist
LINE 1: ...companyNumber", pqo_recipient.numTax as "numTax", pqo_recipi...
2016-11-14 11:54:48.287 ***** ERROR ***** For query : select pqo_recipient.id as "id", pqo_recipient.name as "name", pqo_recipient.companyNumber as "companyNumber", pqo_recipient.numTax as "numTax", pqo_recipient.bank as "bank", pqo_recipient.idle as "idle", pqo_recipient.bankName as "bankName" from pqo_recipient where pqo_recipient.idle=0 and ((1=1)) order by pqo_recipient.id desc
2016-11-14 11:54:48.287 ***** ERROR ***** Strack trace :
2016-11-14 11:54:48.287 ***** ERROR ***** #0 Sql->query called at [/var/www/projeqtor/tool/jsonQuery.php:535]
I fixed deleting the row in columnselector table and setting to false the variable $allFields in ColumnSelector model. I presume that I could instead correct the layout line in
<th field="bankName" width="25%">${bankName}</th>
Best regards
Antonio Giarratana
18 Nov 2016 22:29 #2 by babynus
Replied by babynus on topic Recipient layout
This is due to quite old migration.
Just go to column select and click "Refresh" button.
This is not mandatory (see above)
This will not solve anything : ${bankName} just stands for display name
