ProjeQtOr free project management software - Affectation to a project - ProjeQtOr
10 Nov 2016 12:09 #1 by kugan49
I have two concerns:
- It is possible for a project manager to define an assignment on the project, the problem is that it also selects the type and there, we can choose administrator.
- And if the resource reconnects she sees the buttons giving access to screens that were visible only to the administrator. (the rights of modifications seem to have been preserved)
Best regards
Kugan
10 Nov 2016 13:32 #2 by protion
Replied by protion on topic Affectation to a project
You can set a default type for each resource, which should partly solve your problem after be careful at the time of assignment does not make mistakes, and control once the recorded activity
cordially
Bonjour
Il est possible de définir un type par défaut pour chaque resource, ce qui devrait en partie régler votre problème, après il faut faire attention au moment des affectation de ne pas faire d'erreur, et de contrôler une fois l'activité enregistrée
Cordialement
The following user(s) said Thank You: kugan49
10 Nov 2016 13:47 #3 by kugan49
Replied by kugan49 on topic Affectation to a project
Thanks but maybe it could be corrected on future version ?
10 Nov 2016 19:46 #4 by babynus
Replied by babynus on topic Affectation to a project
What is your version ?
This should not occur on V5.5.4 as it's been fixed on V5.5.0 : project leader cannot add team member with profile Over his default one.
Take care that to define this right, profiles are "ordered" depending on sort order value.
This means that if you have profile with sort order < sort order of admin profile, you can add resource to project with Admin profile.
And it is normal to have screens displayed depending on all available profiles.
This is done to be able to have a project member with project leader rights on one project.
He then should have access to project leader screens for this project.
