ProjeQtOr free project management software - Bill print error - ProjeQtOr
Bill print error
26 Oct 2016 15:21 #1 by antonio.grr
Bill print error was created by antonio.grr
Hi.
I encountered a problem while trying to print a bill in pdf format from Bills page. It seems that html to pdf converterd find html tags closed in wrong order.
I fixed the bug changing the code in ObjectDetail.php from
} else if (substr($col, 0, 5) == '_spe_') { // if field is _spe_xxxx, draw the specific item xxx
$item=substr($col, 5);
if ($internalTable) echo '<td>';
else echo '<tr><td colspan=2>';
echo $obj->drawSpecificItem($item); // the method must be implemented in the corresponidng class
else echo '</td></tr>';
to
$item = substr($col, 5);
if ($internalTable) {
if ($internalTable % $internalTableCols == 0) {
echo '</td><td>' . $cr;
$internalTableCurrentRow++;
} else {
echo '</td><td>';
} else {
// echo '<td>';
} else {
echo '</td></tr>';
I'm not sure that this changes are safe for all usages of the module.
Best regards
26 Oct 2016 18:07 #2 by babynus
Replied by babynus on topic Bill print error
Thanks for the fix.
We'll test it and include it in next release if it bring no regression elswhere.
