ProjeQtOr free project management software - [SOLVED] Impossible de saisir un topic avec ie 11 et Edge - ProjeQtOr
17 Oct 2016 10:40 #1 by oboisse
Avec ces versions d'IE, il est impossible de voir le code captcha.
17 Oct 2016 14:46 - 17 Oct 2016 15:13 #2 by krowry
Hello oboisse,
We tested with Edge and we have no problem with the captcha.
Can you check your configuration of IE ? Maybe something block the captcha ?
Last edit: 17 Oct 2016 15:13 by krowry.
17 Oct 2016 16:02 #3 by oboisse
I'va attached a screenshot of Captcha area with my Edge. Idem with ie 11.
Hopefully, I have another computer with ie 10.
For information, it's idem with Firefox 48.0.2
All on Windows 10.
17 Oct 2016 16:27 #4 by babynus
Did you try the refresh button to get a new image ?
Could you also check fthe console or network traffic for 404 errors ?
