ProjeQtOr free project management software - Can not copy a project - ProjeQtOr
21 Sep 2016 13:26 #1 by thierry.kaufmant
I just installed the new version 5.5.1 and now I can not copy a project.
I had to switch back to version 5.4.3
21 Sep 2016 14:45 #2 by babynus
Replied by babynus on topic Can not copy a project
Could you give more details ?
What is the issue ?
Do you have any error in log file ?
Do you have any error in browser console ?
NB : I just tried with V5.5.1 and could copy several projects (some with sub-projects) without any issue.
22 Sep 2016 10:19 #3 by thierry.kaufmant
hi
below the error message displayed in the log
2016-09-22 10:11:39.299 ***** ERROR ***** Exception-[42601] SQLSTATE[42601]: Syntax error: 7 ERREUR: affectations multiples pour la même colonne « lastupdatedatetime »
2016-09-22 10:11:39.300 ***** ERROR ***** For query : update project set id='41' , name='copie' , creationdate='2016-09-22' , lastupdatedatetime='2016-09-22 10:11:39' , idstatus='14' , lastupdatedatetime='2016-09-22 10:11:39' where id=41
2016-09-22 10:11:39.301 ***** ERROR ***** Strack trace :
2016-09-22 10:11:39.303 ***** ERROR ***** #0 Sql->query called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:1048]
2016-09-22 10:11:39.304 ***** ERROR ***** #1 SqlElement->updateSqlElement called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:636]
2016-09-22 10:11:39.305 ***** ERROR ***** #2 SqlElement->saveSqlElement called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:490]
2016-09-22 10:11:39.306 ***** ERROR ***** #3 SqlElement->save called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\ProjectMain.php:641]
2016-09-22 10:11:39.307 ***** ERROR ***** #4 ProjectMain->save called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\tool\copyProjectTo.php:83]
2016-09-22 10:11:39.309 ***** ERROR ***** Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERREUR: la transaction est annulée, les commandes sont ignorées jusqu'à la fin du bloc
de la transaction
2016-09-22 10:11:39.310 ***** ERROR ***** For query : select * from indicatordefinition where indicatordefinition.nameIndicatorable='Project' and indicatordefinition.idle=0
2016-09-22 10:11:39.311 ***** ERROR ***** Strack trace :
2016-09-22 10:11:39.312 ***** ERROR ***** #0 Sql->query called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:1791]
2016-09-22 10:11:39.313 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:674]
2016-09-22 10:11:39.314 ***** ERROR ***** #2 SqlElement->saveSqlElement called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:490]
2016-09-22 10:11:39.315 ***** ERROR ***** #3 SqlElement->save called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\ProjectMain.php:641]
2016-09-22 10:11:39.317 ***** ERROR ***** #4 ProjectMain->save called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\tool\copyProjectTo.php:83]
2016-09-22 10:11:39.318 ***** ERROR ***** Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERREUR: la transaction est annulée, les commandes sont ignorées jusqu'à la fin du bloc
de la transaction
2016-09-22 10:11:39.319 ***** ERROR ***** For query : select * from plugin where plugin.idle=0
2016-09-22 10:11:39.320 ***** ERROR ***** Strack trace :
2016-09-22 10:11:39.321 ***** ERROR ***** #0 Sql->query called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:1791]
2016-09-22 10:11:39.322 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\Plugin.php:331]
2016-09-22 10:11:39.323 ***** ERROR ***** #2 Plugin->getActivePluginList called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\Plugin.php:460]
2016-09-22 10:11:39.325 ***** ERROR ***** #3 Plugin->getTriggeredEventList called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\Plugin.php:445]
2016-09-22 10:11:39.326 ***** ERROR ***** #4 Plugin->getEventScripts called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:493]
2016-09-22 10:11:39.327 ***** ERROR ***** #5 SqlElement->save called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\ProjectMain.php:641]
2016-09-22 10:11:39.328 ***** ERROR ***** #6 ProjectMain->save called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\tool\copyProjectTo.php:83]
2016-09-22 10:11:39.329 ***** ERROR ***** Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERREUR: la transaction est annulée, les commandes sont ignorées jusqu'à la fin du bloc
de la transaction
2016-09-22 10:11:39.330 ***** ERROR ***** For query : select * from plugintriggeredevent where plugintriggeredevent.idle=0
2016-09-22 10:11:39.331 ***** ERROR ***** Strack trace :
2016-09-22 10:11:39.333 ***** ERROR ***** #0 Sql->query called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:1791]
2016-09-22 10:11:39.334 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\Plugin.php:462]
2016-09-22 10:11:39.335 ***** ERROR ***** #2 Plugin->getTriggeredEventList called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\Plugin.php:445]
2016-09-22 10:11:39.336 ***** ERROR ***** #3 Plugin->getEventScripts called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:493]
2016-09-22 10:11:39.337 ***** ERROR ***** #4 SqlElement->save called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\ProjectMain.php:641]
2016-09-22 10:11:39.338 ***** ERROR ***** #5 ProjectMain->save called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\tool\copyProjectTo.php:83]
2016-09-22 10:11:39.340 ***** ERROR ***** Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERREUR: la transaction est annulée, les commandes sont ignorées jusqu'à la fin du bloc
de la transaction
2016-09-22 10:11:39.341 ***** ERROR ***** For query : select * from planningelement where planningelement.topRefType='Project' and planningelement.topRefId=2 order by wbsSortable asc
2016-09-22 10:11:39.342 ***** ERROR ***** Strack trace :
2016-09-22 10:11:39.343 ***** ERROR ***** #0 Sql->query called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:1791]
2016-09-22 10:11:39.344 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\PlanningElement.php:1384]
2016-09-22 10:11:39.345 ***** ERROR ***** #2 PlanningElement->copyStructure called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\tool\copyProjectTo.php:85]
2016-09-22 10:11:39.346 ***** ERROR ***** Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERREUR: la transaction est annulée, les commandes sont ignorées jusqu'à la fin du bloc
de la transaction
2016-09-22 10:11:39.348 ***** ERROR ***** For query : select * from dependency where 1=0
2016-09-22 10:11:39.349 ***** ERROR ***** Strack trace :
2016-09-22 10:11:39.350 ***** ERROR ***** #0 Sql->query called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\persistence\SqlElement.php:1791]
2016-09-22 10:11:39.351 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\model\PlanningElement.php:1448]
2016-09-22 10:11:39.352 ***** ERROR ***** #2 PlanningElement->copyStructureFinalize called at [C:\Program Files (x86)\NetMake\v8\wwwroot\projeqtor\tool\copyProjectTo.php:90]
2016-09-22 10:11:39.528 ..... SCRIPT .... 192.168.0.96 /projeqtor/view/objectMain.php
2016-09-22 10:11:39.540 ..... SCRIPT .... 192.168.0.96 Page=objectMain.php
2016-09-22 10:11:39.599 ..... SCRIPT .... 192.168.0.96 ->/view/objectMain.php
2016-09-22 10:11:39.602 ..... SCRIPT .... 192.168.0.96 ->/view/objectList.php
2016-09-22 10:11:39.624 ..... SCRIPT .... 192.168.0.96 ->/tool/displayFiletrList.php
2016-09-22 10:11:39.632 ..... SCRIPT .... 192.168.0.96 ->/tool/listColumnSelector
2016-09-22 10:11:39.684 ..... SCRIPT .... 192.168.0.96 ->/view/objectDetail.php
2016-09-22 10:11:39.687 ..... SCRIPT .... 192.168.0.96 ->/view/objectButton.php
2016-09-22 10:11:39.727 ..... SCRIPT .... 192.168.0.96 ->/tool/getObjectCreationInfo.php
2016-09-22 10:11:39.760 ..... SCRIPT .... 192.168.0.96 /projeqtor/tool/refreshVisibleProjectsList.php
2016-09-22 10:11:39.772 ..... SCRIPT .... 192.168.0.96 Page=refreshVisibleProjectsList.php
2016-09-22 10:11:40.106 ..... SCRIPT .... 192.168.0.96 /projeqtor/tool/jsonQuery.php
2016-09-22 10:11:40.147 ..... SCRIPT .... 192.168.0.96 Page=jsonQuery.php
2016-09-22 10:11:40.224 ..... SCRIPT .... 192.168.0.96 ->/tool/jsonQuery.php
2016-09-22 10:11:40.311 ..... SCRIPT .... 192.168.0.96 /projeqtor/tool/saveDataToSession.php
2016-09-22 10:11:40.323 ..... SCRIPT .... 192.168.0.96 Page=saveDataToSession.php
2016-09-22 10:11:40.420 ..... SCRIPT .... 192.168.0.96 /projeqtor/view/objectDetail.php
2016-09-22 10:11:40.435 ..... SCRIPT .... 192.168.0.96 Page=objectDetail.php
2016-09-22 10:11:40.481 ..... SCRIPT .... 192.168.0.96 ->/view/objectDetail.php
2016-09-22 10:11:40.490 ..... SCRIPT .... 192.168.0.96 ->/view/objectButton.php
2016-09-22 10:11:40.520 ..... SCRIPT .... 192.168.0.96 ->/tool/getObjectCreationInfo.php
2016-09-22 10:11:40.555 ..... SCRIPT .... 192.168.0.96 /projeqtor/view/menuProjectSelector.php
2016-09-22 10:11:40.570 ..... SCRIPT .... 192.168.0.96 Page=menuProjectSelector.php
2016-09-22 10:11:40.633 ..... SCRIPT .... 192.168.0.96 Project(*)->drawSubProjects(selectField=selectedProject, recursiveCall=, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.678 ..... SCRIPT .... 192.168.0.96 Project(1)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.690 ..... SCRIPT .... 192.168.0.96 Project(2)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.702 ..... SCRIPT .... 192.168.0.96 Project(6)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.713 ..... SCRIPT .... 192.168.0.96 Project(9)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.725 ..... SCRIPT .... 192.168.0.96 Project(10)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.738 ..... SCRIPT .... 192.168.0.96 Project(12)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.749 ..... SCRIPT .... 192.168.0.96 Project(23)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.761 ..... SCRIPT .... 192.168.0.96 Project(24)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.773 ..... SCRIPT .... 192.168.0.96 Project(26)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.785 ..... SCRIPT .... 192.168.0.96 Project(27)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.797 ..... SCRIPT .... 192.168.0.96 Project(28)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:40.808 ..... SCRIPT .... 192.168.0.96 Project(30)->drawSubProjects(selectField=selectedProject, recursiveCall=1, limitToUserProjects=1, limitToActiveProjects=1)
2016-09-22 10:11:41.202 ..... SCRIPT .... 192.168.0.96 /projeqtor/tool/jsonList.php
2016-09-22 10:11:41.214 ..... SCRIPT .... 192.168.0.96 Page=jsonList.php
2016-09-22 10:11:49.562 ..... SCRIPT .... 192.168.0.96 Page=checkAlertToDisplay.php
22 Sep 2016 19:02 #4 by babynus
The log gave me some hints and I then could reproduce the issue : is occurs onyl when DB is PostgrSql...
Ticket #2307 recorded
