ProjeQtOr free project management software - Ticket screen organisation issue - ProjeQtOr
13 Sep 2016 14:03 #1 by c.pache
Hi !
I have an issue on ticket screen : since I used custom screen plugin and moved product/component/version items, I have a strange behavior. Linked element section isn't at the right place. I reverted back my customization but the issue is the same. Look at this screenshot, Linked elements are under Product section.
File Attachment:
Do you have a file or something where to reorganize the screen properly ?
Thank you for your answer.
13 Sep 2016 17:10 #2 by babynus
Issue recorded in Plugin roadmap.
NB : if you use reset feature available on V2.0 of plugin, you'll retreive correct display.
14 Sep 2016 11:13 #3 by c.pache
I know that but I'll loose all my customized fileds... do you think It can be solved without reset ? I have done a big customization work on this screen...
14 Sep 2016 11:30 #4 by babynus
We'll bring improvements on the plugin.
You can send us your file /model/custom/Ticket.php. We'll fix things.
14 Sep 2016 12:22 #5 by c.pache
Since I have the concerned file path, I fixed it by myself ;)
