ProjeQtOr free project management software - [SOLVED] difference between fisrt and second view of dashboard - ProjeQtOr
05 Sep 2016 12:34 #1 by cmarechal
i have noticed a little issue :
when you open the dashboard you have an array for projects which is different afterward when you choose a particular filter (non closed, todo, all)
(see images attached)
thanks,
Christophe
05 Sep 2016 14:30 #2 by babynus
Sorry, but I don't see any difference between your 2 print screens
05 Sep 2016 15:59 #3 by cmarechal
there is a difference indeed :
have a look at the 4th and the 5th column on each image...
05 Sep 2016 16:34 #4 by babynus
You're right, columns "Left" and "Margin" disepeared :S
Issue recorded as Ticket #2292
The following user(s) said Thank You: cmarechal
