ProjeQtOr free project management software - [SOLVED] error in sub-project display for a team member - ProjeQtOr
01 Sep 2016 18:05 - 01 Sep 2016 18:06 #1 by cmarechal
I noticed an issue which is a not empty display in the sub-project field (on "poject" view").
When you are a member even if the actual project is not a sub project.
The field displays the name of the project with the smallest wbs number. Thus, this field is underlined as compulsory but is not normally.
(see attached files)
Last edit: 01 Sep 2016 18:06 by cmarechal.
02 Sep 2016 10:09 #2 by babynus
Issue recorded as Ticket #2291
The following user(s) said Thank You: cmarechal
02 Sep 2016 11:06 #3 by cmarechal
perfect !
Thanks,
Christophe
22 May 2018 11:41 #4 by Envergus
I have the same problem, could you please advise? what was the solution (I can't find the ticket #2291 when I connect to the roadmap as guest)
Thanks,
22 May 2018 14:35 #5 by babynus
Ticket is #3390...
Fix is included in patch 7.0.9
22 May 2018 14:48 #6 by Envergus
Dear Babynus,
Thank you for the reply.
Before I have posted I upgraded to V7.0.9 and still the same problem.
I appreciate your help
