ProjeQtOr free project management software - plantages a la sauvegarde des imputations - ProjeQtOr
23 Aug 2016 10:55 #1 by jeanmoulin
bonjour
J'ai des plantage systématiques lorsque un utilisateur tente de sauvegarder ses imputations : le log parle de depassement de capacité de quelque chose semble il
je suis en version . 5.1.5
ci dessous le log :
2016-08-23 00:10:56.436 ***** ERROR ***** ERROR *****
2016-08-23 00:10:56.436 ***** ERROR ***** on file '/var/www/projeqtor/tool/saveImputation.php' at line (85)
2016-08-23 00:10:56.436 ***** ERROR ***** cause = Error - Maybe max_input_vars is too small in php.ini
23 Aug 2016 13:35 #2 by babynus
PLEASE POST IN ENGLISH.
_____
You're facing the max_input_vars issue.
Increase the value of this parameter in your php.ini or try to reduce number of lines displayed in the Real Work Allocation screen (use checkbox options to reduce itms listed or close some activities)
28 Aug 2016 17:59 #3 by JoVed
I get the same issue
Where is the php.ini file or where do I have to modify the max_vars ?
TIA
JoVed
28 Aug 2016 18:01 #4 by babynus
php.ini is in your php installation.
Use your OS search feature to look for it.
