ProjeQtOr free project management software - [SOLVED] project dashboard error - ProjeQtOr
18 Aug 2016 14:12 #1 by cmarechal
after updating to V 5.4.4 (Postgresql), i encounter problem with the new menu "dashboard ticket".
in the file log, it is written :
"2016-08-18 14:01:14.114 ***** ERROR ***** ERROR *****
2016-08-18 14:01:14.115 ***** ERROR ***** on file '/home/wwwroot/projeqtor/view/dashboardTicketMain.php' at line (247)
2016-08-18 14:01:14.115 ***** ERROR ***** cause = Undefined index: nbLine
could someone help me ?
Thanks,
Christophe
18 Aug 2016 14:50 #2 by babynus
Replied by babynus on topic project dashboard error
Issue recorded as Ticket #2272
18 Aug 2016 14:53 #3 by babynus
Issue fixed.
Try and install attached patch, and tell us is all is correct now.
Is all is correct, patch will then be included in V5.4.5 patch.
The following user(s) said Thank You: cmarechal
18 Aug 2016 15:25 #4 by cmarechal
Replied by cmarechal on topic project dashboard error
everything is ok (just tested). Thanks !
18 Aug 2016 15:35 #5 by maged.mostafa
I had the same issue and confirmed that the error disappeared with replacing the file in the attached patch.
