ProjeQtOr free project management software - [SOLVED] Error after upgrade from V5.3.5 to V5.4.1 - ProjeQtOr
07 Jul 2016 13:06 #1 by nicop
Getting error. Any advice
2016-07-07 12:58:26.272 ===== TRACE =====
2016-07-07 12:58:26.273 ===== TRACE ===== DATABASE UPDATE COMPLETED TO VERSION V5.4.1
2016-07-07 12:58:26.273 ===== TRACE ===== =====================================
2016-07-07 12:59:40.377 ===== TRACE ===== NEW CONNECTED USER 'admin'
2016-07-07 13:00:12.806 ***** ERROR ***** ERROR *****
2016-07-07 13:00:12.806 ***** ERROR ***** on file '/home/xxx/public_html/xxxx/projeqtor/view/objectDetail.php' at line (1936)
2016-07-07 13:00:12.806 ***** ERROR ***** cause = ob_end_flush(): failed to delete and flush buffer. No buffer to delete or flush
07 Jul 2016 14:18 #2 by babynus
Strange, I don't get any issue...
Maybe it depen,ds on PHP version.
Fix is to comment lines
1936 ob_end_flush();
1974 ob_start();
in /view/objectDetail.php
Issue is recorded asd Ticket #2186
Fix will be deployed in patch V5.4.2
The following user(s) said Thank You: nicop
07 Jul 2016 16:53 #3 by nicop
I made the changes and working like a charm now.
