ProjeQtOr free project management software - [SOLVED] Plug-in question - ProjeQtOr
13 Jun 2016 11:06 #1 by ekolossov
Plug-in question was created by ekolossov
I cannot submit question about plug-in as it always coming with "The CAPTCHA solution was incorrect.". Something wrong with the question form...
My question is - when you will have version for Screen Customization plug-in which support 5.3.5?
13 Jun 2016 11:22 #2 by babynus
Replied by babynus on topic Plug-in question
this plugin compatibility is ProjeQtOr >= V5.2.3
It means the plugin is compatible with ProjeQtOr V5.2.3 and over, including V5.3.5
The following user(s) said Thank You: ekolossov
