ProjeQtOr free project management software - 5 errors encountered during upgrade to 5.3.3 - ProjeQtOr
11 Jun 2016 23:02 #1 by briandlees
I have completely rebuilt my site and installed 5.3.3 from scratch. I have 5 errors encountered during the database upgrade to 5.3.3. They are all of the same format so I have only reproduced the logfile entries for the first error below. I am using OpenSuse LEAP 42.1, Apache2, Postgresql, PHP5.5.14. Any ideas please?
2016-06-11 21:48:38.158 ***** ERROR ***** Exception-[22P02] SQLSTATE[22P02]: Invalid text representation: 7 ERROR: invalid input syntax for type numeric: ""
LINE 1: select * from parameter where idUser ='' and idProject is n...
2016-06-11 21:48:38.158 ***** ERROR ***** For query : select * from parameter where idUser ='' and idProject is null and parameterCode='editor'
2016-06-11 21:48:38.158 ***** ERROR ***** Strack trace :
2016-06-11 21:48:38.158 ***** ERROR ***** #0 Sql->query called at [/data/nfs/www/projeqtor/model/persistence/SqlElement.php:1740]
2016-06-11 21:48:38.158 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/data/nfs/www/projeqtor/model/Parameter.php:687]
2016-06-11 21:48:38.158 ***** ERROR ***** #2 Parameter->getUserParameter called at [/data/nfs/www/projeqtor/tool/projeqtor.php:2726]
2016-06-11 21:48:38.158 ***** ERROR ***** #3 getEditorType called at [/data/nfs/www/projeqtor/model/persistence/SqlElement.php:799]
2016-06-11 21:48:38.158 ***** ERROR ***** #4 SqlElement->insertSqlElement called at [/data/nfs/www/projeqtor/model/persistence/SqlElement.php:627]
2016-06-11 21:48:38.158 ***** ERROR ***** #5 SqlElement->saveSqlElement called at [/data/nfs/www/projeqtor/model/persistence/SqlElement.php:475]
2016-06-11 21:48:38.158 ***** ERROR ***** #6 SqlElement->save called at [/data/nfs/www/projeqtor/model/History.php:101]
2016-06-11 21:48:38.158 ***** ERROR ***** #7 History->store called at [/data/nfs/www/projeqtor/model/persistence/SqlElement.php:1001]
2016-06-11 21:48:38.159 ***** ERROR ***** #8 SqlElement->updateSqlElement called at [/data/nfs/www/projeqtor/model/persistence/SqlElement.php:621]
2016-06-11 21:48:38.159 ***** ERROR ***** #9 SqlElement->saveSqlElement called at [/data/nfs/www/projeqtor/model/persistence/SqlElement.php:475]
2016-06-11 21:48:38.159 ***** ERROR ***** #10 SqlElement->save called at [/data/nfs/www/projeqtor/model/UserMain.php:836]
2016-06-11 21:48:38.159 ***** ERROR ***** #11 UserMain->save called at [/data/nfs/www/projeqtor/db/maintenance.php:339]
2016-06-11 21:48:38.159 ***** ERROR ***** #12 include called at [/data/nfs/www/projeqtor/tool/loginCheck.php:52]
2016-06-11 21:48:38.166 ***** ERROR ***** Exception-[22P02] SQLSTATE[22P02]: Invalid text representation: 7 ERROR: invalid input syntax for type numeric: ""
12 Jun 2016 11:12 #2 by babynus
I guess these errors are reported before db update starts.
If it is the case, don't care about them.
12 Jun 2016 12:43 #3 by briandlees
Thanks for the reply but I'm not sure whether they are before or after. I have attached the relevant portion of the log.
12 Jun 2016 12:58 #4 by babynus
You faced specific PostgreSql issues.
We will work on this.
Recorded as Ticket #2131
28 Jun 2016 20:00 #5 by briandlees
Do you know whether there has been any progress please?
28 Jun 2016 23:29 #6 by babynus
This issue is fixed since V5.3.5.
