ProjeQtOr free project management software - [SOLVED] Bug sur le coût des activités - ProjeQtOr
09 May 2016 16:14 #1 by jeanyves.allou
Bonjour,
je rencontre un bug sur le coût des activités. Dans mon pays, le cout d'une ressource par jour est 250 000 XOF (XOF monnaie locale).
Lorsque je mentionne ce coût 250 000 pour une ressource (img1), et je l'affecte à une activité , je rencontre un bug le montant se change en 99 999,99 (img2).
Après une imputation de deux jours, normalement sur l'activité je devrais avoir 250 000 * 2 =500 000 , mais jai 199 999,9 (img3).
Pouvez vous, sil vous plait, m'aider à corriger ce bug? Merci
12 May 2016 14:46 #2 by babynus
Please post in English.
This issue has already been replied and no longer exists in V5.3.3 (check this in Demo)
12 May 2016 16:24 #3 by jeanyves.allou
i use the latest version 5.3.3.
this issue exist and remains.
please fix that
12 May 2016 17:27 #4 by babynus
I confirm that what you describe is fixed on V5.3.3
But if you save, you get an error message :
SQLSTATE[22003]: Numeric value out of range: 1264 Out of range value for column 'dailyCost' at row 1
This will be fixed in V5.4.0
12 May 2016 17:34 #5 by jeanyves.allou
No no babynus, assign user "admin" to an activity. and click on pencil to modify assign, you will see cost : 99 999, 9 (ig2 in attached)
i confirm i use v5.3.3 ( ig1 in attached)
12 May 2016 18:10 #6 by babynus
I confirm that I don't have same behavior than yours.
Mabe your use case is different...
By the way, fix will be done on V5.4.0
But notice that it may have restricted target, and all amonts will not be changed.
So possibly for big projects, let's say 1000 days of work, you may face issues on other items.
One workaround, that you may use right now, is to change unit to KXOF : 1 KXOF = 1000 XOF.
This will work even with current verison.
