ProjeQtOr free project management software - Translation issues - ProjeQtOr
Translation issues
04 May 2016 14:49 #1 by gduran
Translation issues was created by gduran
I've been working on the Dutch translation over the last week as I found that the included Dutch translation is far from complete. Also quite some translations needed to be revised.
At the home page I find "Welcome" at the top and "Welcome to ProjectOr web application" just below the first.
I can't find these strings in the XLS translation file. Moreover Projector in the second string is spelled wrong!!! Obviously this should be ProjeQtOr.
Futhermore I've discovered some variables not present int the XLS file:
These are:
colIdTargetProductVersion
colIdOriginalProductVersion
colIdOriginalComponentVersion
colIdTargetComponentVersion
These show up in their respective variable name.
I also will be happy to share this translation work but can't find instructions how to proceed but it may be possible that I've overlooked...
GD
04 May 2016 15:32 #2 by babynus
Replied by babynus on topic Translation issues
Yes, Dutch translation has not been updated for long ... :(
These are not translated fields.
It is a default "Message", that can be changed or removed on the menu Tools > Messages
This will be fixed in next version (Projector is old name for ProjeQtOr)
It is because file available for download is V5.2. My mistake, I did not deployed V5.3 version for xls file : it is fixed now...
To share your translation, you can post you XLS file on this tread of sent it to us : support AT projeqtor.org
Thanks in advance for your contribution.
04 May 2016 16:13 #3 by gduran
Replied by gduran on topic Translation issues
Thanks for your quick response. :woohoo
I've just downloaded the XLS file but does not contain these variables...
GD
04 May 2016 16:19 - 04 May 2016 16:20 #4 by gduran
Please find herewith the Dutch translation..
GD
Last edit: 04 May 2016 16:20 by gduran. Reason: no attachment
04 May 2016 16:21 #5 by babynus
File not attached (maybe you should zip it, I'm not sure Forum accepts xls files)
About xls file, I've just verified and latest available version for download contains missing variables : www.projeqtor.org/files/lang.xls
04 May 2016 16:22 - 04 May 2016 16:22 #6 by babynus
Could you please post the XLS file and not the JS file ?
Last edit: 04 May 2016 16:22 by babynus.
