ProjeQtOr free project management software - [SOLVED] Reporting error : deprecated constructor - ProjeQtOr
22 Apr 2016 11:56 - 22 Apr 2016 15:00 #1 by sebastien.perrier
I got a major bug report on almost all reports since I've fix the Mutex.php bug ...
Here is the log when I select the report 'Current status / status of ongoing work' :
ERROR : Methods with the same name as their class will not be constructors in a future version of PHP; pData has a deprecated constructor
in pData.class
at line 48
Could you please help me ?
ProjeQtor version 5.1.5 on Debian
Last edit: 22 Apr 2016 15:00 by sebastien.perrier.
22 Apr 2016 22:44 - 22 Apr 2016 22:48 #2 by babynus
Same issue as for Mutex exists on pData in /external/pChart/pData.class
Fix should be the same, but other issues of same kind may still exist in external libraries....
ProjeQtOr is not validated for PHP 7 :(
Not yet...
[Edit] the 3 classes in pChart directories are concerned
Last edit: 22 Apr 2016 22:48 by babynus.
The following user(s) said Thank You: sebastien.perrier
25 Apr 2016 10:27 - 25 Apr 2016 10:27 #3 by sebastien.perrier
Ok, I've applied the same correction to following files :
pChart.class :
- function pChart($XSize,$YSize) transform in function __construct($XSize,$YSize)
pData.class :
- function pData() transform in function __construct()
and it works :-)
Thank you very much babynus
Last edit: 25 Apr 2016 10:27 by sebastien.perrier.
