ProjeQtOr free project management software - Delete link beetwen Ticket and task - ProjeQtOr
07 Sep 2011 13:34 #1 by Guest
I've link the ticket #2 link with an activity by the listbox (planning activity).
Then i've remove the link. When i want to delete the activity, I've a msgbox as it's impossible because the ticket #1 (older ticket, closed) is also attach.
The ticket #1 is closed, and haven't link with no-one activity.
Best regards,
Olivier
07 Sep 2011 18:00 #2 by babynus
I've registered this as ticket #409 because it looks like a bug.
Could you check by reading ticket #1 that it is realy not linked to the activity ?
07 Sep 2011 18:34 #3 by Guest
Yes, I confirm that tocket #1 is not link.
Olivier
07 Sep 2011 19:49 #4 by babynus
Hi, I could not reproduce :
My test case :
Create activity #1
Create ticket #1, no parent activity
Create ticket #2, parent activity = activity #1
Delete activity #1 : error, 1 ticket linked
Delete ticket #2 : OK
Delete activity #1 : OK
Really, as the controle is based only on the existence of a ticket with idActivity = "1", if no item exists, th con,trole can't block.
Can you check in database : existence of Ticket where idActivity = the id of the activity you try to delete (even if the ticket is closed, the deletion of the activity is refused : the activity can only be closed, not deleted)
If issue persist, can you send print screen of details to This email address is being protected from spambots. You need JavaScript enabled to view it. ?
Thx.
08 Sep 2011 11:51 #5 by Guest
Hie,
It's OK now.
Olivier
09 Sep 2011 00:01 #6 by babynus
What was wrong ?
