ProjeQtOr free project management software - [SOLVED] Import data error "Impossible to load class AssignmentPlanningElement" - ProjeQtOr
[SOLVED] Import data error "Impossible to load class AssignmentPlanningElement<br/>"
14 Mar 2016 18:37 #1 by mcristian
I've successfully imported "Activity" and "Work" elements.
When I try to import "Assignment" no messages are displayed on form (neither errors or some info) and in log file I can see these messages:
2016-03-14 18:10:52.634 ===== TRACE ===== Importation : File type CSV
2016-03-14 18:10:52.634 ===== TRACE ===== File Name : ../files/attach//import/IMPORT_assignment_sample1.csv
2016-03-14 18:10:52.670 ***** ERROR ***** Impossible to load class AssignmentPlanningElement<br/> => Not found in ../model/custom/AssignmentPlanningElement.php <br/> => Not found in ../model/AssignmentPlanningElement.php <br/> => Not found in ../model/persistence/AssignmentPlanningElement.php <br/>
Just for some troubleshooting I try also to import "Task" using a bad file format, same result: no errors on form and log messages recorded.
Atteched the CSV file.
Thank you.
Regards.
14 Mar 2016 23:41 #2 by babynus
file is not attached
15 Mar 2016 09:25 - 15 Mar 2016 09:27 #3 by mcristian
Sorry (I didn't click Insert button :unsure: ) !!!!
Here the file content ...
id;project;type of item;element id;resource;function;comments;assigned work;left work;rate (%);closed
;1;Assignment;8;4;3;"Commento";10;10;100;
Last edit: 15 Mar 2016 09:27 by mcristian.
15 Mar 2016 09:43 #4 by babynus
Issue is on type of item.
Type of item / element id refers to refType / refId in database.
It indicates to which item the assignment refers.
For instance Activity / 1 yould mean an assignment for Activity #1
This involes that ActivityPlanningElement must exist.
It cannot be Assignment.
As of Today, you can add Assignment for :
Activity
Meeting
TestSession
The following user(s) said Thank You: mcristian
15 Mar 2016 10:10 #5 by mcristian
With this new version of the file I can import assignments for the actvities.
;1;Activity;8;4;3;"Commento";10;10;100;
Thanks!!!
