ProjeQtOr free project management software - [SOLVED] Problem mails - ProjeQtOr
14 Mar 2016 15:21 #1 by lblaise
Problem mails was created by lblaise
Hi, Projeqtor no longer send any mails since the upgrade.
When I modify parameters in the global parameters, I have a message which tell me that parameters are saved but when I come back on the screen, the parameters have disapeared.
14 Mar 2016 15:48 #2 by babynus
Replied by babynus on topic Problem mails
check your parameters.php file and remove all parameters about email.
You shoul have only db info and log info in parameters.php file.
How did you migrate ?
From wich version to which one ?
The following user(s) said Thank You: lblaise
17 Mar 2016 07:56 #3 by lblaise
Replied by lblaise on topic Problem mails
Thanks for your answer, I've solved the problem by deleting mail parameters in the file parameters.php
05 Oct 2016 10:42 #4 by Hedia
Replied by Hedia on topic Problem mails
I want to change the body of the email transferred to the projeqtor contacts according to our need how
I want eliminated the specifications table below
05 Oct 2016 15:17 #5 by babynus
You cannot unles you change the code.
05 Oct 2016 15:24 #6 by Hedia
the code to modify or are in any file
