ProjeQtOr free project management software - Model not found (after upgrade) - ProjeQtOr
08 Mar 2016 11:01 - 08 Mar 2016 11:04 #1 by El Wallos
Hi
Last firday,I upgraded from 5.1.4 to 5.2.4 (I don't know if it is the problem), and yesterday, I had this error on the log:
2016-03-07 10:16:41.225 ***** ERROR ***** Impossible to load class Contract
=> Not found in ../model/custom/Contract.php
=> Not found in ../model/Contract.php
=> Not found in ../model/persistence/Contract.php
Can I ignore this error?
Last edit: 08 Mar 2016 11:04 by El Wallos.
08 Mar 2016 11:11 - 08 Mar 2016 11:11 #2 by El Wallos
I attch one error more on the log: (perhaps, it is a different issue)
016-03-04 15:33:45.099 ***** ERROR ***** ERROR *****
2016-03-04 15:33:45.100 ***** ERROR ***** on file '/var/www/html/projeqtor/tool/jsonQuery.php' at line (436)
2016-03-04 15:33:45.100 ***** ERROR ***** cause = Undefined variable: objClass
Last edit: 08 Mar 2016 11:11 by El Wallos.
08 Mar 2016 22:51 #3 by babynus
About first issue, there is no Class Contract in ProjeQtOr, nor reference to it.
Did you change some code ?
Did you add new class ?
Second issue is about an already reported but : if you try to sort on work value, you'll get this issue.
This issue will be fixed on V5.3.0
14 Mar 2016 13:51 #4 by El Wallos
babynus wrote: About first issue, there is no Class Contract in ProjeQtOr, nor reference to it.
No code or class was added. Just upgrade was done.
babynus wrote: Second issue is about an already reported but : if you try to sort on work value, you'll get this issue.
