ProjeQtOr free project management software - [SOLVED] Installation issue - ProjeQtOr
25 Feb 2016 14:06 - 25 Feb 2016 14:07 #1 by rbarragan
Installation issue was created by rbarragan
Hi!
I'm trying to install Projeqtor 5.2.4 in a hosting service. I've created the database and set the file permissions. But when I try to access with admin/admin I receive a undefined error. The log file say:
016-02-25 13:54:27.264 ***** ERROR ***** ERROR *****
2016-02-25 13:54:27.264 ***** ERROR ***** on file '/usr/home/tE1238upumdG/project.sinergiacrm.org/web/projeqtor/tool/loginCheck.php' at line (38)
2016-02-25 13:54:27.265 ***** ERROR ***** cause = Undefined index: sessionSalt
2016-02-25 13:54:27.268 ***** ERROR ***** ERROR *****
2016-02-25 13:54:27.269 ***** ERROR ***** on file '/usr/home/tE1238upumdG/project.sinergiacrm.org/web/projeqtor/tool/loginCheck.php' at line (46)
2016-02-25 13:54:27.269 ***** ERROR ***** cause = Undefined index: sessionSalt
2016-02-25 13:54:27.274 ***** ERROR ***** ERROR *****
2016-02-25 13:54:27.274 ***** ERROR ***** on file '/usr/home/tE1238upumdG/project.sinergiacrm.org/web/projeqtor/tool/loginCheck.php' at line (50)
2016-02-25 13:54:27.274 ***** ERROR ***** cause = Undefined index: sessionSalt
and no tables neither changes was occurred in database.
I've also installed a local version (it worked) and I've tried to create the database with sql statements exported from local version, but the problem has been the same.
Now I have a empty database and a clean installation, and the logfile is the attached file.
Please, can you tell me what is wrong?
Thanks alot.
Last edit: 25 Feb 2016 14:07 by rbarragan. Reason: Attachement lost
25 Feb 2016 21:50 #2 by babynus
Replied by babynus on topic Installation issue
you have a session issue.
possibly a session mimatch.
try and clean php sessions.
26 Feb 2016 13:33 #3 by rbarragan
Replied by rbarragan on topic Installation issue
Hi babynus,
I've cleaned all my session files and the result is the same.
27 Feb 2016 11:21 #4 by babynus
Try and clean browser cache also.
Do you have any other PHP application running on same server ?
29 Feb 2016 09:22 #5 by rbarragan
There is only projeqtor running on the virtual server.
I attach the javascript console log.
29 Feb 2016 11:32 #6 by babynus
Could you please expand one or the errors logged in the console ?
