ProjeQtOr free project management software - Template parameters and xml tags in description disappeared with upgrade to 5.1.5 - ProjeQtOr
15 Feb 2016 11:39 - 15 Feb 2016 15:41 #1 by ekolossov
Template parameters in description disappeared with upgrade to 5.1.5.
For example:
template<int I, typename T>
struct B
template<typename T1, typename T2>
struct D : B<1, T1> B<2, T2>
now shown as:
template
struct B
template
struct D : B<1, T1>, B<2, T2>
Same we can see with xml tags - they are disappeared as well...
Is it possible to go back to simple text field?
Last edit: 15 Feb 2016 15:41 by ekolossov.
15 Feb 2016 16:40 #2 by babynus
New text editor fileds strip unexpected tags.
Cannot change this behavior.
If you want to revert to simple text fields, you just have to change database fields format from 'mediumtext' to 'varchar(4000)'
01 Mar 2016 17:51 #3 by ask
Does this setting have any impact on the Notes? I've change the field type from mediumtext to varchar(4000) and yet the field is still uses a smart editor.
02 Mar 2016 09:23 #4 by babynus
I'm afraid no.
Notes are designed in a fixed pop-up that has no dynamic formatting.
10 Jan 2017 08:20 - 10 Jan 2017 08:45 #5 by ekolossov
We have upgraded to 6.0.5 and this problem appeared again despite database fields format still is 'varchar(4000)'.
Please advice ASAP as we cannot use it with this problem!
Editor selection has no effect at all!
Last edit: 10 Jan 2017 08:45 by ekolossov.
10 Jan 2017 20:43 #6 by babynus
I cannot reproduce.
On V6.0.5, if I change format of field "description" on table "ticket" to VARCHAR(4000), I get correct display as plaint text field and not full hml editor.
Could you please detail behavior your are facing, as it does not seem to be exactly like privious one ?
