ProjeQtOr free project management software - [SOLVED] Problem with monthly reports - ProjeQtOr
12 Feb 2016 11:20 - 12 Feb 2016 11:20 #1 by lfd
Since the last update (5.2.2), monthly reports don’t return any result if the required month is prior to the current month. This problem also occurs if the required month comes after the current month.
I don’t have any problem with the weekly reports that have a date prior or post the current date.
Thank you for your help
Last edit: 12 Feb 2016 11:20 by lfd.
12 Feb 2016 20:35 #2 by babynus
Issue will be fixed on V5.2.3
15 Feb 2016 10:18 #3 by lfd
Replied by lfd on topic Problem with monthly reports
OK,
thanks you for answer.
I installed the V5.2.3 and the problem isn't reproduce
Time to create page: 0.075 seconds
