ProjeQtOr free project management software - [SOLVED] No display for closed items - Page 2 - ProjeQtOr
26 May 2016 19:38 #7 by babynus
Replied by babynus on topic No display for closed items
This issue is fixed on V5.3.3
08 Aug 2016 11:33 #8 by test31
Replied by test31 on topic No display for closed items
I'm not sure it works well when closed project is a sub-project of an open project.
For example in demo today :
Project "Projet QAP" is open
Sub-project "Nouveau Projet 1" is closed
From project list, if i just check "show closed items", "Nouveau Projet 1" does not appear.
The only way i found is also to :
- to check "show closed items" in project selector parameter
- choose "Projet QAP" in project selector
- check "show closed items" in project list
08 Aug 2016 12:06 #9 by babynus
Yes, this option, also called the "archive mode" is mandatory to see items of closed projects.
08 Aug 2016 12:16 #10 by test31
However, if project is not a sub-project (for example in demo "MyProject"), we don't need to check "show closed items" in project selector parameter.
Why this difference between projects and sub-projects?
08 Aug 2016 12:31 - 08 Aug 2016 15:45 #11 by babynus
It is because of the affectation.
Project leaders have access rights to projects they are affected to.
But when a project is closed, affectation is also closed, so project leader "looses" access rights on project. To retreive rights, he needs to set the "archive mode".
For sub-project, rights may be inherited from affectation on top project.
So if top project is not closed, affectation is still active, and archive mode is not required to see data of a closed sub-project.
Last edit: 08 Aug 2016 15:45 by babynus.
08 Aug 2016 13:31 #12 by test31
Thanks for these detailed explanations.
