ProjeQtOr free project management software - [SOLVED] Users unable to login after upgrading to most current release - Page 6 - ProjeQtOr
16 Feb 2016 14:09 #31 by babynus
50 projects is not heavy.
1000 projects is.
Anonymize is to replace all names so that you don't provide confidential data.
19 Feb 2016 17:29 #32 by iconic
Hi, I was trying to anonymize database but i could not find user table, There are models named as User and UserOld in project files but i could not find any database for it. Can you please provide me which is the table used for storing the users?
19 Feb 2016 18:20 #33 by babynus
Object User extends UserMain.
In UserMain, you find $_databaseTableName = 'resource';
This means that table for user object is resource (this tabe is shared by User, Resource and Contact)
23 Feb 2016 18:29 #34 by iconic
Sorry for the delay in reply, some other issues came up.
I have exported database and anonymized the resource table. Can you please tell me how should i send you database? I tried to send you private message but it does not have any option to upload file.
24 Feb 2016 18:35 #35 by babynus
send it to This email address is being protected from spambots. You need JavaScript enabled to view it.
24 Feb 2016 19:04 #36 by iconic
I have sent email with zip file of database attached to the email address you mentioned. You will find projeqtor.sql after extracting it.
Please let me know if you don't receive it. I have sent email with subject "Database for ProjeQtOr which is having problem with account logins."
Thank You
