ProjeQtOr free project management software - [SOLVED] Problem to diplay "is subproject of" - ProjeQtOr
20 Jan 2016 11:28 #1 by El Wallos
Hi all
I detected one issue when I want to display the column "is sub project of" on project tab, any project are displayed. Do you have the same behavior?
It was tested on mozilla and Chrome, same problem.
20 Jan 2016 11:53 #2 by babynus
Issure confirmed.
Recorded as Ticket #1942
20 Jan 2016 11:55 #3 by test31
Same pb on my installation.
If 'is subproject of' selected, no project are displayed on project screen.
20 Jan 2016 13:41 #4 by El Wallos
Hi Babynus,
I attach the error on the log.
2016-01-20 13:39:53.743 ***** ERROR ***** Exception-[23000] SQLSTATE[23000]: Integrity constraint violation: 1052 Column 'codeType' in where clause is ambiguous
2016-01-20 13:39:53.743 ***** ERROR ***** For query : select project.id as id, project.name as name, convert(concat(T1.sortOrder,'#split#',T1.name,'#split#',COALESCE(T1.color,'')) using utf8) as colorNameStatus, projectplanningelement.progress as progress, projectplanningelement.plannedEndDate as plannedEndDate, convert(concat(T2.sortOrder,'#split#',T2.name,'#split#',COALESCE(T2.color,'')) using utf8) as colorNameProject, T3.fullName as nameResource, project.idResource, projectplanningelement.assignedWork as assignedWork, projectplanningelement.realWork as realWork, projectplanningelement.priority as priority,project.idProject as idproject from project left join status as T1 on project.idStatus = T1.id left join planningelement as projectplanningelement on (projectplanningelement.refId=project.id and projectplanningelement.refType='Project') left join project as T2 on project.idProject = T2.id left join resource as T3 on project.idResource = T3.id left join planningelement as T4 on ( T4.refType='Project' and T4.refId = project.id ) where project.idle=0 and ( (project.id not in (0) or project.id is null ) and (project.id not in (0) or project.id is null or (project.idResource='7') ) and (project.id not in (0) or project.id is null or (project.idUser='7') ) or codeType='TMP' ) and T4.priority <> '500' order by projectplanningelement.wbsSortable , project.sortOrder
2016-01-20 13:39:53.744 ***** ERROR ***** Strack trace :
2016-01-20 13:39:53.744 ***** ERROR ***** #0 Sql->query called at [/var/www/html/projeqtor/tool/jsonQuery.php:493]
Hope it helps you to solve it. :)
20 Jan 2016 19:28 #5 by babynus
Hi
Thanks for the log.
I got it as I could reproduce.
Thanks anyway.
20 Jan 2016 19:32 #6 by babynus
Fixed.
Fix is to replace in lines 143 and 170 (2 times) in /tool/jsonQuery.php
$queryWhere.= " or codeType='TMP' ";
with
$queryWhere.= " or $table.codeType='TMP' ";
