ProjeQtOr free project management software - [SOLVED] Bar print on portfolio gant planning - ProjeQtOr
20 Jan 2016 09:48 #1 by test31
I try to use the portfolio gant planning report, and especially the print version.
On the screen bars for planning appear correctly, but they are not on printed paper.
Is there any prerequisite on printer?
They don't appear either if I try to print in PDF Creator document instead of real printer.
20 Jan 2016 10:50 #2 by babynus
You must set options in your browser to print images and colors.
The following user(s) said Thank You: test31
20 Jan 2016 11:14 #3 by test31
OK. It works.
I use Firefox and we need to check in "File"/"Page Setup" option Print page background.
I tried with Chrome and it's OK without any modifications.
