ProjeQtOr free project management software - [SOLVED] [5.2.1] User parameters not saved until restart? - ProjeQtOr
19 Jan 2016 11:09 - 16 Feb 2016 09:30 #1 by papjul
Good day,
Since 5.2.1, users parameters are not saved until I disconnect and log in again. I think it worked in 5.2.0.
How to reproduce:
- Go to user parameters
- Change a parameter (display history for example)
- Save
- Go to user parameters again, display history has its old value
Since I have some custom developments on my ProjeQtOr version, I applied a diff from ProjeQtOr 5.2.0, so if you can't reproduce, please tell me and I will see if I missed a "id" becoming "idData" somewhere or something like this…
Last edit: 16 Feb 2016 09:30 by papjul.
19 Jan 2016 12:06 #2 by climb4fun
Hi Papjul,
I already tested it in my environment and it worked well.
Did you test it in DEMO environment here in ProjQtiOr? Of not, my be you should give him a try.
climb4fun
19 Jan 2016 12:10 #3 by papjul
You can't change user parameters in demo.projeqtor.org, that's why I couldn't check.
Guess I will have to check with another fresh installation of ProjeQtOr to compare…
19 Jan 2016 12:19 - 19 Jan 2016 12:19 #4 by climb4fun
Yes, you are right, in demo user parameters not enabled. Helped by you, I discovered this today for the first time.
Last edit: 19 Jan 2016 12:19 by climb4fun.
19 Jan 2016 13:04 #5 by babynus
I tested and first all seemed to work.
But when trying "Display history" option, I could reproduce issue : saved value is not retreived.
Ticket #1938 recorded.
NB : user parameters is disabled is Demo because everybody uses same few users, and so should not change some parameter values (such as language...)
19 Jan 2016 19:29 #6 by babynus
Fixed !!
Fix is to replace lines 48-52 in /tool/saveDataToSession.php from
if (in_array($id, getParamtersList('userParameter'))) {
    // OK, it is a user parameter
  } else if (in_array($id, getParamtersList('globalParameter'))) {
    // OK, it is a global parameter
to
if (array_key_exists($id, Parameter::getParamtersList('userParameter'))) {
  } else if (array_key_exists($id, Parameter::getParamtersList('globalParameter'))) {
