ProjeQtOr free project management software - [SOLVED] List on Real Work Allocation is not sort - ProjeQtOr
18 Jan 2016 16:05 #1 by El Wallos
Hi
On Chrome, I saw that some lists (RWA, diary...) are not sorted by alphabetic order while on Firefox, it is.
Is it normal?
18 Jan 2016 16:07 #2 by babynus
1) there should have no difference on sort order depending on browser... :silly:
2) Projects are never aphabetically sorted : there are always sorted on WBS (some reports are not and they will be fixed)
18 Jan 2016 17:09 #3 by El Wallos
babynus wrote: 1) there should have no difference on sort order depending on browser... :silly:
You are right, but now I detected that I was this behavior because I was logged on Firefox with admin user and on Chrome with a supervisor user. Why I have this difference?
babynus wrote: 2) Projects are never aphabetically sorted : there are always sorted on WBS (some reports are not and they will be fixed)
I don't tell about project, only about list of ressources on diary and RWA.
19 Jan 2016 11:36 #4 by babynus
OK, I understand .
You're right, list of resource should be alphabetically sorted.
It can not be browser dependent, but possibly profile dependant.
I made few tests, I discovered that when specific access is "all elements on all project", sort order is correct, but when it is "elements of own projects", sort order is wrong.
Ticket #1936 recorded
19 Jan 2016 13:11 - 19 Jan 2016 13:13 #5 by El Wallos
Excelent, thanks for your feedback.
I'm not fully crazy ;-) ... just a little bit :evil:
Last edit: 19 Jan 2016 13:13 by El Wallos.
