ProjeQtOr free project management software - [SOLVED] Mail problem - Page 2 - ProjeQtOr
12 Jan 2016 19:42 - 12 Jan 2016 19:44 #7 by babynus
Replied by babynus on topic Mail problem
Ticket #1918 is not delivered yet.
You have to apply patch (change code) on your own or wait for V5.2.1
But if you are on V5.1.5, possibly it is not the same issue.
Check for errors in log file.
Last edit: 12 Jan 2016 19:44 by babynus.
13 Jan 2016 11:58 #8 by ceka44
Replied by ceka44 on topic Mail problem
But this patch is already in the file sendMail.php :?
See attached file
13 Jan 2016 12:22 #9 by ceka44
I inserted "/usr/sbin/sendmail" in the field "Sendmail Path" and the problem is solved.
But this information is already in parameters (see the result of phpinfo function).
Is it normal to have to specify again this information in projeqtor ?
13 Jan 2016 17:21 #10 by babynus
It is not "normal" but may be a wrokaround : specifying the sendMail, you force the use of sendMail instead of default phpMailer.
13 Jan 2016 17:23 #11 by ceka44
Thanks for your answer Babynus
