ProjeQtOr free project management software - [SOLVED] Some changes not saved with postgres database - Page 2 - ProjeQtOr
11 Jan 2016 15:52 - 11 Jan 2016 15:55 #7 by pipobru
Yes, the probleme is when apply fix for all (and mySQL) Any error in log file:
Final patch (to keep it valid for MySql) will also add change of line 1829 in /model/persistence/SqlElement.php from
$selectFields.=" sum($fldName) as sum".ucfirst($fld);
to
$selectFields.=" sum($fldName) as sum".strtolower($fld);
Last edit: 11 Jan 2016 15:55 by pipobru.
11 Jan 2016 16:00 #8 by babynus
OK, ticket #1920 recorded.
Will investigate.
The following user(s) said Thank You: pipobru
11 Jan 2016 16:37 #9 by pipobru
link or same problem with TOPIC: CK Editor ?
11 Jan 2016 17:03 #10 by babynus
No, I don't think it is linked.
I think that CK Editor issue is a javascript issue (question of delay between the onChange is triggered and the form is sent to the server)
Your issue is PostgreSql specific issue (cannot reproduce on MySql)
11 Jan 2016 20:06 #11 by pipobru
For me when apply the procedure write in this post the pb is not present, records is correct. For me, you can close this bug.
