ProjeQtOr free project management software - [SOLVED] CK Editor - Page 2 - ProjeQtOr
[SOLVED] CK Editor
12 Jan 2016 09:13 #7 by babynus
Replied by babynus on topic CK Editor
Fixed !
For information, issue does not occur if you save using [CTRL]+S.
Fix is to replace saveObject() function in /view/js/projeqtor.js from
function saveObject() {
  if (waitingForReply)  {
    showInfo(i18n("alertOngoingQuery"));
    return true;
  if (editorInFullScreen()) return;
  dojo.byId("saveButton").blur();
  submitForm("../tool/saveObject.php","resultDiv", "objectForm", true);
to
    return true;
  for(name in CKEDITOR.instances) { // Necessary to update CKEditor field whith focus, otherwise changes are not detected
    CKEDITOR.instances[name].updateElement();
The following user(s) said Thank You: pipobru
12 Jan 2016 09:26 #8 by pipobru
Replied by pipobru on topic CK Editor
For me it work fine ! Big thanks !
12 Jan 2016 10:35 #9 by swyngy
Replied by swyngy on topic CK Editor
me too
no more pb
thks
