ProjeQtOr free project management software - Workflow Error - ProjeQtOr
Workflow Error
02 Sep 2011 18:31 #1 by Guest
Workflow Error was created by Guest
Hie,
When i go in List of Values / Workflows, select any-one workflow I have in the section Workflow Diagram this message:
ERROR : An error occured on 2011-09-02 at 18:26:49
I havn't remark if it's since I've added some news status.
Do you have any idea about that?
Best regards,
Olivier
03 Sep 2011 00:56 #2 by babynus
Replied by babynus on topic RE : Workflow Error
I coumld not reproduce.
Could you have a look at the log file to fetch the complete error message ?
In fact, when the gui displays "ERROR : An error occured on 2011-09-02 at 18:26:49 ", you should have in the log file a message at the same timestamp.
You may also set debug level to 4 and reproduce, the error message will directly be displayed.
Please forwrd the error message so that I can investigate.
05 Sep 2011 17:01 #3 by Guest
Replied by Guest on topic RE : Workflow Error
The log file indicates this lines:
2011-09-05 16:59:43 ***** ERROR ***** on file '/var/www/projectorria/model/Workflow.php' at line (227)
2011-09-05 16:59:43 ***** ERROR ***** cause = Undefined offset: 2
Thank for help,
Best regards,
Olivier
05 Sep 2011 23:06 #4 by babynus
Issue registered as ticket #402.
I could not reproduce yet.
Could you send to This email address is being protected from spambots. You need JavaScript enabled to view it. a print sreen detailing the reproduction of issue ?
Regards.
06 Sep 2011 08:35 #5 by Guest
I Have the error Recipient adress rejected 4.1.2 when i try to send you a mail at This email address is being protected from spambots. You need JavaScript enabled to view it.
Best regard,
Olivier S
06 Sep 2011 10:03 #6 by babynus
Sorry email is This email address is being protected from spambots. You need JavaScript enabled to view it.
