ProjeQtOr free project management software - List of contacts not correct - Page 2 - ProjeQtOr
18 Dec 2015 11:10 #7 by 002514
Replied by 002514 on topic List of contacts not correct
Hi Babynus
I sent informations requested by email to This email address is being protected from spambots. You need JavaScript enabled to view it.
Yannick
18 Dec 2015 11:32 #8 by babynus
Received.
I investigate and will give information soon ;)
18 Dec 2015 11:47 - 18 Dec 2015 11:47 #9 by babynus
I found the issue :woohoo: thanks to your data ;) .
It is due to translatable fields in the "combo button" view (when you click on the hourglass).
As a workaround :
=> goto contact list (in the environmental parameters).
=> the list of contacts should appear correctly
=> in the column selector (button ) remove (uncheck) the "profile" field.
=> all should be correct then
Fix will be provided soon.
Last edit: 18 Dec 2015 11:47 by babynus.
18 Dec 2015 12:03 - 18 Dec 2015 12:06 #10 by babynus
Fix !
in /view/js/projeqtor.js, replace lines 1690 to 1696 from
if (i18nMessagesCustom[str]) {
    ret = i18nMessagesCustom[str];
  } else if (i18nMessages[str]) {
    ret = i18nMessages[str];
  } else if (i18nPluginArray && i18nPluginArray[str]) {
    ret =  i18nPluginArray[str];
to
if (top.i18nMessagesCustom[str]) {
    ret = top.i18nMessagesCustom[str];
  } else if (top.i18nMessages[str]) {
    ret = top.i18nMessages[str];
  } else if (top.i18nPluginArray && top.i18nPluginArray[str]) {
    ret =  top.i18nPluginArray[str];
Patch will be included in V.5.2.0 (and patch if required)
NB : this issue does not require immediate patch as it happens only
=> on combo list for Contacts (or Resources or Users),
=> and if Profile is selected in the list of columns
=> and if you added new profile
Last edit: 18 Dec 2015 12:06 by babynus.
The following user(s) said Thank You: 002514
18 Dec 2015 12:56 #11 by 002514
Thanks a lot for your quick answer. Now it's OK
I will wait your fix (5.2.0)
bye
