ProjeQtOr free project management software - [SOLVED] Wrong total for assigned and reassessed ? - ProjeQtOr
03 Nov 2015 09:56 #1 by papjul
I don't know if it's an issue or if you have an explanation for this but total for assigned and reassessed should be 171 d (on screenshot), why is it 175 d and 174,5d?
Thank you,
03 Nov 2015 10:51 #2 by babynus
Assigned can be different from validated.
I don't see all lines, so cannot sum up all assigned.
For re-assessed, it is always real+left : so calculation seems correct.
03 Nov 2015 11:38 #3 by papjul
OK for reassessed I didn't know what it was.
All lines are here, what are you missing? What do I need to screenshot?
03 Nov 2015 11:39 #4 by papjul
We deleted all assignments and 4 days remained on the root project.
03 Nov 2015 18:30 #5 by babynus
1) First I did not see that last lines are not summed up on the parent task above (grey line). If is surely because they are directly under the project.
2) If after deletion you still have assigned work, I may be because you have a closed activity. Try and display activiites with "show closed" checkbox checked.
04 Nov 2015 09:18 #6 by papjul
Indeed it was due to a closed activity!
Thank you!
