ProjeQtOr free project management software - [SOLVED] Problem after installing the 5.0.6 - ProjeQtOr
16 Oct 2015 13:13 #1 by cchable
I installed from scratch release. After login, the login screen returns.
I also have a 4.5.6 version that works fine, but the migration to 5.0.6 has the same problem.
No error in projeqtor and Apache logs.
16 Oct 2015 15:09 #2 by babynus
Any error in Browser console ?
Did you try and clean browser cache ?
16 Oct 2015 15:49 #3 by cchable
Cache cleared.
IE & Forefox
Console log in firefox:
"=> 129ms | page='../tool/loginCheck.php' | destination='loginResultDiv' | formName=loginForm' (server:113ms, client:16ms)" projeqtor.js:75:2
ReferenceError: assignment to undeclared variable resultNode projeqtor.js:743:13
ReferenceError: assignment to undeclared variable resultWidget projeqtor.js:744:15
ReferenceError: assignment to undeclared variable url projeqtor.js:755:6
Object { message: "Unable to load ../tool/saveDataToSe…", stack: ".cache["dojo/errors/create"]/</</_4…", response: Object, status: 0, responseText: "", xhr: XMLHttpRequest } dojo.js:15:102024
.cache["dojo/_base/xhr"]/</_3c4() dojo.js:15
.cache["dojo/_base/xhr"]/</dojo._ioSetArgs/<() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
.cache["dojo/_base/Deferred"]/</dojo.Deferred/this.errback() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
_189() dojo.js:15
_187() dojo.js:15
.cache["dojo/_base/xhr"]/</dojo.xhr/<() dojo.js:15
.cache["dojo/Deferred"]/</_3e7() dojo.js:15
.cache["dojo/Deferred"]/</_3e1() dojo.js:15
.cache["dojo/Deferred"]/</_3e6/this.reject() dojo.js:15
.cache["dojo/Deferred"]/</_3ed() dojo.js:15
_31b() dojo.js:15
_328() dojo.js:15
TypeError: variable year redeclares argument projeqtor.js:2312:7
TypeError: variable text redeclares argument projeqtor.js:2469:5
ReferenceError: assignment to undeclared variable avoidRecursiveRefresh projeqtor.js:238:0
19 Oct 2015 12:50 #4 by babynus
What is strange is the line
It seems saveDataToSession.php fails.
Maybe you have cookie issue (retreiving session from old connection with previous version).
First, try and delete cookies linked to projeqtor calls.
If this does not fix issue, in dev tools [F12], open network tab and look for request to saveDataToSession.php.
Post request and response, it may give some hints.
19 Oct 2015 16:28 #5 by cchable
Thx for your reply.
I deleted cookies.
Here are two videos to explain what is happening.
There are not a lot of info when tracing of saveDataToSession.php (the second video), only the headers.
What do you like more?
Video 1: www.ceria.be/projeqtor/001.avi
Video 2: www.ceria.be/projeqtor/002.avi
19 Oct 2015 16:47 #6 by babynus
So I see in Video 1 that you are connected correctly, but immediatly disconnected.
It is strange 'cos your get this directly when getting main page : you directly have "?lostConnection=true" in the url.
So I see two possibiities :
1) you changes somthing is the parametering that sets login page as default page
Check all lines in parameters table where parameterCode='startPage'
2) there is some parameter in config that the application interprets as some acking attempt.
Then, you should have at least a trace in the log file.
Try and set debug level to 4 and post log file here.
