ProjeQtOr free project management software - Conflict between ProjeQtOr and Bitnami SuiteCRM - ProjeQtOr
29 Sep 2015 16:58 - 29 Sep 2015 17:02 #1 by eliot
Hello everyone,
We have installed a PHP application named "Bitnami SuiteCRM" and, after that, we installed ProjeQtOr, using the Apache and MySQL servers SuiteCRM had installed.
The problem is we can't run ProjeQtor properly when we use the same brower to open both applications.
Here are the steps :
1. Login to ProjeQtor
2. Browse ProjeQtOr. No problem.
3. Login to SuiteCRM in another tab.
4. Try to browse ProjeqtOr. Nothing happens anymore when you click the menu.
The problem only occurs when the same user uses the same browser to access both applications. So this seems to be a SESSION issue.
I have been investigating and found that a ticket had already been opened about a SESSION problem:
Ticket #1729: Store current user out of $_SESSION['user'] to avoid conflict with other applications
But this issue seems to have been fixed with 5.0.1... and we use 5.0.5.
Any idea?
Thanks for sharing knowledge.
Last edit: 29 Sep 2015 17:02 by eliot.
29 Sep 2015 20:09 #2 by babynus
Conflict may come from other share value.
To be sure, could you add 1 line on line 129 of /tool/projeqtor.php, like this :
 * ============================================================================ main controls ============================================================================
debugLog($_SESSION);
Then run test (blocking one), retrieve projeqtor log file and post it here (or send it to This email address is being protected from spambots. You need JavaScript enabled to view it.)
30 Sep 2015 10:58 - 30 Sep 2015 11:17 #3 by eliot
Thanks for your answer, babynus.
Which log file do you need?
EDIT: I found this one: "projeqtor\files\logs\projeqtor_20150930.log"
I paste it below (I only changed the username mentioned).
2015-09-30 09:55:06.054 ===== TRACE ===== NEW CONNECTED USER 'eliot'
2015-09-30 11:07:58.681 ===== TRACE ===== NEW CONNECTED USER 'eliot'
Nothing special. It just mentions my two connection tests this morning.
Last edit: 30 Sep 2015 11:17 by eliot.
30 Sep 2015 11:15 #4 by babynus
ProjeQtOr log file.
By default it is stored in /files/logs : 1 file per day.
Log files are also available through admin screen in ProjeQtOr (you don't have to connect to server to download log file...)
30 Sep 2015 11:19 #5 by eliot
I found it while you were answering (I edited my previous post).
30 Sep 2015 12:54 #6 by babynus
Sorry, you also have to change log level to 3 in parameters.php file :
$logLevel='3';
