ProjeQtOr free project management software - minor issue : adding multiple predecesor task link via ctrl+click - ProjeQtOr
21 Aug 2011 22:06 #1 by ThierrC49
In planning screen, when you define the predecesor, you can select several task by clicking on project task with Ctrl key pressed, but only on task has been selected
two solution :
- disable the multi-selection in control box
- treat it as multi task link (best of course :))
BR
Thierry,
22 Aug 2011 12:18 #2 by babynus
Registered as ticket #389.
