ProjeQtOr free project management software - [SOLVED] $enforceUTF8 always unset in Sql.php - ProjeQtOr
21 Aug 2015 13:21 - 21 Aug 2015 13:29 #1 by seb1981
I have some problem with utf8 character on my mysql database. It is exactly the same issue explained here: http://www.projeqtor.org/fr/forum-fr/2-submit-issues/5799-utf8-on-display,-wrong-in-database-because-twice-converted-solved?start=18#8625
I have done everything from this post but i have always the problem.
So I modified Sql.php as follow:
//if (isset($enforceUTF8) and $enforceUTF8) {
    	  self::$connexion->query("SET NAMES utf8");
After this, all is good. I check my parameter.php file and $enforceUTF8 = true is set.
Why $enforceUTF8 is not load as paramDbType from the GlobalParameter ?
because if I add this code before, everything ok
$enforceUTF8 = Parameter::getGlobalParameter('enforceUTF8'); // load enforceUTF8 parameter
// Could solve some erroneous default storing in non utf8 format
Have a nice day
Environment
PROJEQTOR
Version 5.0.5
MySQL
Serveur: Localhost via UNIX socket
Version du serveur: 5.5.40-0+wheezy1
Version du protocole: 10
Jeu de caractères pour MySQL: UTF-8 Unicode (utf8)
WEB SERVER
Apache/2.2.22 (Debian)
Version du client MySQL: 5.5.40
Extension PHP: mysqli
PHP
PHP 5.4.36-0+deb7u1 (cli) (built: Dec 31 2014 07:31:33)
Copyright (c) 1997-2014 The PHP Group
Zend Engine v2.4.0, Copyright (c) 1998-2014 Zend Technologies
Last edit: 21 Aug 2015 13:29 by seb1981. Reason: Adding environment specification
21 Aug 2015 14:00 #2 by babynus
You are right, there is an issue :
In Sql.php, line 246, add 1 line after getConnection definition :
private static function getConnection() {
    global $enforceUTF8;
Because it is a DB paraemter, and all db parameters are stored in parameters.php file.
The following user(s) said Thank You: seb1981
21 Aug 2015 14:23 #3 by seb1981
That works !
Thank you !
