ProjeQtOr free project management software - [SOLVED] Backup and Restore - Page 2 - ProjeQtOr
19 Aug 2015 18:48 - 19 Aug 2015 19:20 #7 by ijack30
Replied by ijack30 on topic Backup and Restore
This is. I don't know if that can help
With Chrome, error is explicit.
formName=listForm'
Failed to load resource: the server responded with a status of 404 (Not Found)
=> 996ms
I saved another time ALL /Files/directory, and restore on a new server.
restore again BD
no change !
I don't understand..
Last edit: 19 Aug 2015 19:20 by ijack30.
19 Aug 2015 19:22 #8 by babynus
Replied by babynus on topic Backup and Restore
What was the request that responded with 404 (Not found) ?
It is not the one your joined, as they both responded 200 (OK)
About request your showed, could you show response body ? (corps de la réponse)
Last, could you check existence of folder /files/attach/attachment_303 ? (pay attention, not attachement_303 but attachment_303)
Does this folder exist and contain the file you try to download ?
19 Aug 2015 19:38 #9 by ijack30
here is for attachment 472
/files/attach/attachment_272 exist, ans PDF file is into it
Capt7 is strange.. On Windows server, a same action I can see
http://windowsserver/projeqtor/view/main,php
19 Aug 2015 19:44 - 19 Aug 2015 19:44 #10 by ijack30
No.. Sorry.. I don't know what i did...
Capt7-2 on new server
Capt8 on old server
Last edit: 19 Aug 2015 19:44 by ijack30.
19 Aug 2015 19:51 #11 by babynus
The "initiateur" does not matter.
It just says which event generated the request.
But response seems empty.
Could you check :
1) log file (in ../files/logs) : is there any error logged
2) database, table attachment with id='272'.
"fileName" should be name of file you try to download.
"subDirectory" should be "${attachmentDirectory}\attachment_272/"
19 Aug 2015 19:59 - 19 Aug 2015 20:11 #12 by ijack30
Log file
2015-08-19 13:42:11.417 ***** ERROR ***** download.php : ../files/attach/\\attachment_472\\Resistance tissus de Superior.pdf not found
Attach directory
admin@projeqtor:/var/www/projeqtor/files/attach/attachment_472$ ls -l
total 1264
-rwxr-xr-x 1 www-data root 1291579 mar 18 13:44 Resistance tissus de Superior.pdf
With Phpmyadmin
attachment table
Subdirectory = ${attachmentDirectory}\attachment_472\
Last edit: 19 Aug 2015 20:11 by ijack30.
