ProjeQtOr free project management software - phpMailer problems. - Page 2 - ProjeQtOr
phpMailer problems.
02 Aug 2015 17:47 #7 by VERNCon
Replied by VERNCon on topic phpMailer problems.
II am able to send mails out using port 25, but I need to have "milters" and other "essential" security devices disabled for testing this, so it cannot remain using un-authenticated mail submission past midnight Sunday - I need to restore the disabled security checks by then.
I will try and figure out how to hack things to make a valid client certificate and private key "available" to meet the SSLVerify requirement for php5.6.x (I have valid certificate/key pair & CA sub.class1 certs available for this purpose).
I am not a programmer, and know nothing about php, etc, so I seek your help in trying to get a functional solution.
Cheers,
VERNCon.
03 Aug 2015 19:17 #8 by babynus
Replied by babynus on topic phpMailer problems.
Thanks for your analysis :
It would be preferable to have a patch to the code which allows for a client certificate and private key to be referenced
Request recorded as Ticket #1770
otherwise an upgraded version of phpMailer, v5.2.10 or above which allows for the setting of an insecure connection to the smtp server.
Will try to do this for patch V5.0.4
Ticket #1771 recorded
05 Aug 2015 22:53 #9 by VERNCon
Still not working yet - I have got through the encryption failures - for some reason I cannot figure out, the CA certificate has was failing - it "looked" correct in the soft-link, but it was not working. Once the soft-links were re-hashed and remade, it passed through that phase.
Now it is being blocked when it starts the authentication through Dovecot/PGSQL. PHPMailer appears to send a null PID in the authentication request, and Dovecot drops it.
When I send a mail through the same interface from Thunderbird (not through PHPMailer, but Dovecot/PGSQL), everything works perfectly.
Will try to get more information tomorrow - currently tied up with a DNS upgrade due to BIND and a "critical" defect notice...... :whistle:
06 Aug 2015 13:42 - 06 Aug 2015 13:43 #10 by VERNCon
Hi, a quick note to say
FIXED!!!
Once I installed 5.0.4, (with the updated PHPMailer 5.2.10) that cleared the final problems.:-)
Last edit: 06 Aug 2015 13:43 by VERNCon.
17 Dec 2015 16:43 #11 by ericzen
Replied by ericzen on topic phpMailer problems.
VERNCon wrote: Hi, a quick note to say
FIXED!!!
Hello, I've the same problem on my server. What have you done for fixed this problem ?
I've a postfix with dovecot and TLS. When i try to send a mail, i've a problem of authentification. As my webmail server i search how fixed with
$config = array(
'ssl' => array(
'verify_peer' => false,
'verify_peer_name' => false,
But i don't find where add this code.
So can you explain how you solved ?
EricZEn
