ProjeQtOr free project management software - Dates on problems - Page 2 - ProjeQtOr
Dates on problems
30 Jul 2015 12:42 #7 by babynus
Replied by babynus on topic Dates on problems
the date appears a few seconds, then dissapear
Dou mean that when you select a new status in this list (not using direct change button to next status) the checkbox is checked and the date is set, but few seconds after (doing noting, not saving) the date is cleared ?
30 Jul 2015 13:46 #8 by c.pache
Replied by c.pache on topic Dates on problems
No, when I select a new status directly on list, everything is OK. But when I click on the button :
- Box is checked
- Date is set
- A message appears to tell an email was sent
- when this message dissapears after dfew second, at the same time date dissapears too, doing nothing
30 Jul 2015 14:44 #9 by babynus
OK,
I could reproduce with done date and closed date, but not with handled date.
And this is produced only if type has "lock done" and "lock closed" uncjecked (if they are checked, there is no issue).
Do you confirm it is same case for you ?
30 Jul 2015 15:16 #10 by babynus
Found it !
It was an asynchronous issue, so not systematic.
To fix it, in /view/objectDetail.php, replace line 1370
echo ' onClick="dijit.byId(\'' . $fieldId . '\').set(\'value\',' . $next . ');setTimeout(\'saveObject()\',10);">';
with
echo ' onClick="dijit.byId(\'' . $fieldId . '\').set(\'value\',' . $next . ');setTimeout(\'saveObject()\',100);">';
Ticket #1768.
Will be deployed in V5.0.4 (coming very soon)
The following user(s) said Thank You: c.pache
30 Jul 2015 20:25 #11 by c.pache
It works :)
