ProjeQtOr free project management software - projects are not displayed - ProjeQtOr
10 Jul 2015 20:37 #1 by bsmi
Hello, I just updated to 5.0.2 and not able to see projects in "Projects" window. I am able to see list of projects in the drop down list in upper left. I am using Chrome. Screenshot is attached.
Thank you.
10 Jul 2015 20:54 #2 by babynus
Replied by babynus on topic projects are not displayed
I cannot reproduce.
I need more information to investigate.
1) did you try and clean browser cache ?
2) did you try and select another project ?
3) Do you have any error in ProjeQtOr log file ?
4) Do you have any error in Browser console ?
5) Can you try to open new tab in browser (keep existing connected) and goto :
http://yourserver/projeqtor/tool/jsonQuery.php?objectClass=Project
what is the result ?
10 Jul 2015 21:51 #3 by bsmi
Replied by bsmi on topic projects are not displayed
1)Yes,
2)Yes, all of them the same. I am not able to see list of projects when I click "Projects" in the menu on the left either.
3)Where log file is located?
4) Failed to load resource: the server responded with a status of 404 (Not Found) in Google
Tried on different computer with IE with the same result but no errors in the console.
5) Just shows: {"identifier":"id", "items":[] }
10 Jul 2015 22:20 #4 by babynus
Log file is by default in/files/logs (one file per day)
This kind of response is correct for empty list.
10 Jul 2015 22:44 #5 by bsmi
Attached is zipped log file. After update events start at page 26. Sorry, I will be able to reply to any other message on Monday only.
Thank you.
10 Jul 2015 23:43 #6 by babynus
You had issue during upgrade :
2015-07-10 14:24:41.867 ===== TRACE ===== =====================================
2015-07-10 14:24:41.867 ===== TRACE ===== DataBase actual Version = V4.4.2
2015-07-10 14:24:41.867 ===== TRACE ===== ProjeQtOr actual Version = V5.0.2
2015-07-10 14:24:41.870 ***** ERROR ***** Error on SqlElement to get 'individual' for Class 'ExpenseDetailType' : field 'individual' not found in Database.
2015-07-10 14:24:41.870 ***** ERROR ***** Error on SqlElement to get 'project' for Class 'ExpenseDetailType' : field 'project' not found in Database.
2015-07-10 14:24:42.164 ===== TRACE ===== =====================================
2015-07-10 14:24:42.164 ===== TRACE ===== DATABASE UPDATE COMPLETED TO VERSION V5.0.2
You don't have trace of database update...
