ProjeQtOr free project management software - Can't login in v5.0.1 after installation - Page 2 - ProjeQtOr
09 Jul 2015 13:52 #7 by potzilov
Just tried it. Doesn't work.
Shall I try to install a stable version and see if it works?
09 Jul 2015 14:58 - 09 Jul 2015 14:58 #8 by potzilov
I tried to reconfigure the system and get the following error in the log file (version 5.0.1):
2015-07-09 14:45:59.999 ***** ERROR ***** Exception-[42000] SQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max k
ey length is 767 bytes
2015-07-09 14:46:00.000 ***** ERROR *****    For query : CREATE INDEX planningelementWbsSortable ON `pr_planningelement` (`wbsSortable`);
2015-07-09 14:46:00.000 ***** ERROR *****    Strack trace :
2015-07-09 14:46:00.000 ***** ERROR *****    #0 Sql->query called at [/usr/local/www/projeqtor/db/maintenanceFunctions.php:63]
2015-07-09 14:46:00.000 ***** ERROR *****    #1 runScript called at [/usr/local/www/projeqtor/db/maintenance.php:94]
2015-07-09 14:46:00.000 ***** ERROR *****    #2 include called at [/usr/local/www/projeqtor/tool/loginCheck.php:52]
2015-07-09 14:46:00.001 ===== TRACE =====
2015-07-09 14:46:00.001 ===== TRACE ===== Error # 1 => SQL error while executing maintenance query for version V0.6.0 (see above message)
2015-07-09 14:46:00.001 ===== TRACE ===== *************************************************
Last edit: 09 Jul 2015 14:58 by potzilov.
09 Jul 2015 15:32 #9 by babynus
It is a non blocking issue but could lead to poor performance on planning display (an index has not been created).
To avoid the issue, you must configure MySql to with Innodb_large_prefix=true
09 Jul 2015 21:12 #10 by babynus
Also, V5.0.2 has just been deployed.
Could you check if it fixes your first issue ?
09 Jul 2015 21:25 #11 by potzilov
Just tried it and it seems like the same error, but instead of line 125 it now gives error on line 2594:
2015-07-09 21:22:01.511 ===== TRACE ===== NEW CONNECTED USER 'admin'
2015-07-09 21:22:01.595 ***** ERROR ***** ERROR *****
2015-07-09 21:22:01.596 ***** ERROR ***** on file '/usr/local/www/projeqtor/tool/projeqtor.php' at line (2594)
2015-07-09 21:22:01.596 ***** ERROR ***** cause = getSessionUser(): The script tried to execute a method or access a property of an incomplete object. Please ensure that the class definition "User" of the object you are trying to operate on was loaded _before_ unserialize() gets called or provide a __autoload() function to load the class definition
09 Jul 2015 22:09 - 09 Jul 2015 22:51 #12 by potzilov
Problem solved:
I changed in php.ini from:
session.auto_start = 1
to
session.auto_start = 0
and managed to login. Topic can be closed as far as I'm concerned.
Last edit: 09 Jul 2015 22:51 by potzilov.
