ProjeQtOr free project management software - Program halts when changing the project of an Activity - Page 2 - ProjeQtOr
29 Jun 2015 13:13 #7 by iconic
Here is a pdf of MySQL Configuration
29 Jun 2015 13:14 #8 by iconic
Also I tried setting ''innodb_lock_wait_timeout'' value to 30, 300 and 900 but it did not helped so I had revert back config to value 50.
29 Jun 2015 15:28 #9 by babynus
It seems your default engine is MyISAM.
This engine, although quite performant, do not support transactional (ACID) operations.
So, most possibly your lock issue comes from this point.
Check your tables and try and change engine to InnoDb, it should fix the issue.
05 Aug 2015 05:21 #10 by iconic
I have tried to obtain the my.ini file, however our IT staff have said "There is no way to get my.ini from WHM. "
Is there any other way of having this resolved. It still happens with the upgrade to 5.0.3
05 Aug 2015 14:53 #11 by babynus
No, iti is not possible.
ProjeQtOr uses transactional operations. If your MySql is only compatible with MyISAM files, ProjeQtOr won't work.
Maybe some migration (export and reimport fixing default files would work, but I'm really not sure as innoDb is explicitly defined during table creation.
Maybe you may concider upgrading database or use PostgreSql database (always transactionnal capacble)
