ProjeQtOr free project management software - send mail not work after upgrade to V5.0.0 - Page 2 - ProjeQtOr
17 Jun 2015 18:09 #7 by anisdz2015
its worked fine with 4.7.0 but now with V5.0.0 erreur
17 Jun 2015 19:02 #8 by babynus
If you used V4.7.0, you may have got it from out of ProjeQtOr site :huh:
as it never existed.
Maybe you meant V4.5.7. ;)
Is it really an upgrade on same server, to same smtp, for same instance (same deployment directory) ?
19 Jun 2015 10:51 #9 by anisdz2015
yes, it's an upgrade on same server, to same smtp, for same instance (same deployment directory)
19 Jun 2015 11:38 #10 by mboelke
Helo,
I had a similar problem when upgrading from 4.5.6 to 5.0.0!
Following steps solved the problem:
First I've cleaned all configuration fields in the mailing section, saved and added them again.
Please don't be angry, if it doesn't help ;-)
Mathias
19 Jun 2015 11:50 #11 by babynus
@mboelke : tanks for this workaround, it may help anisdz2015, and give me hint to investigate.
@anisdz2015 : could you check and tell me if this also solves the issue for you ?
20 Jun 2015 21:00 #12 by anisdz2015
hello
I just realized that yesterday I received a notification from the Alert projeqtor server with 5.0.0 there is a notification sent by programmed projeqtor
Otherwise when I try to manually send an email that does not work and I have a message that asks me to contact the administrator
I'll test the hint of mboelke and tell
thank you
