ProjeQtOr free project management software - [SOLVED] [V5] Order doesn't appear in list if no project set - ProjeQtOr
17 Jun 2015 12:13 #1 by papjul
As an administrator, when I create an order with no project selected in the list (optional field), it doesn't show up in the orders list (list area). When I add a project id to this order directly in database, order shows up in the list.
I didn't test other entities, but it might not affect only orders.
I didn't remember having this problem before V5.
Thank you,
17 Jun 2015 13:33 #2 by babynus
You may have discovered a bug.
It is due to V5 new access rights management, that can be different on several projects (different profile can now be defined on each project).
Other entities are not affected as Project is mandatory for most items.
Items that are not Project dependant are correctly managed (Products, Resources, ...)
Item where project is optional are very few :
- document : already taken into account
- bill : was forgotten.
I'll check to be sure there is not other.
Now I wonder why project is not mandatory for bills. Does it really have an interest for you ?
Moveover, for quotes project in mandatory...
(that's why I never faced the issue : I always create bills through copy of quotes)
Ticket #1723 recorded.
Thanks for reporting
17 Jun 2015 13:47 #3 by papjul
babynus wrote: - bill : was forgotten.
It's mandatory on invoices/bills for me, you meant orders?
babynus wrote: I'll check to be sure there is not other.
Requirements, tests cases & tests sessions.
babynus wrote: Now I wonder why project is not mandatory for bills. Does it really have an interest for you ?
I was just testing an order, that's why I didn't fill in all fields, I usually copy from quotations to orders too.
17 Jun 2015 14:46 #4 by babynus
You're right.
Issue exist on Orders, Requirements, Tests cases & Tests sessions.
It will be fixed on next patch.
18 Jun 2015 11:32 #5 by papjul
Issue affects messages too.
19 Jun 2015 00:06 #6 by babynus
Issue fixed.
Fix is just to replace in /tool/projeqtor.php, line 742
} else if ($accessRightRead=='ALL') {
    $queryWhere="($tableAlias$fieldProj not in $listNO or $tableAlias$fieldProj is null)";
    if ($listRES) $queryWhere.=" and ($tableAlias$fieldProj not in $listRES or $clauseRES)";
    if ($listOWN) $queryWhere.=" and ($tableAlias$fieldProj not in $listOWN or $clauseOWN)";
with
    if ($listRES) $queryWhere.=" and ($tableAlias$fieldProj not in $listRES or $tableAlias$fieldProj is null or $clauseRES)";
    if ($listOWN) $queryWhere.=" and ($tableAlias$fieldProj not in $listOWN or $tableAlias$fieldProj is null or $clauseOWN)";
Fix will soon be deployed in patch V5.0.1
