ProjeQtOr free project management software - [SOLVED] err ms Input variables exceeded 3000. To increase the limit change max_input_vars in php.in - ProjeQtOr
06 May 2015 16:34 - 07 May 2015 10:28 #1 by Iaurkano
Hi babynus,
we just met a issue during "imputations".
this message appears only for one user who have a lot of activity.
could you confirm that the modification of the max_input_vars in php.ini will correct the issue.
Thank's a lot for everything.
Last edit: 07 May 2015 10:28 by Iaurkano. Reason: solved indicateur added.
06 May 2015 23:21 #2 by babynus
Almost sure the max_input_vars will fix the issue.
Have a look at the log file to get confirmation.
07 May 2015 10:26 #3 by Iaurkano
hi,
modification done, and now it's working...
Thank's
