ProjeQtOr free project management software - Not possible to send E-mail - ProjeQtOr
29 Apr 2015 14:17 #1 by iqbal.ahmed
Hi :
These are my setting
smtp server : ssl://smtp.gmail.com
smtp port : 464
smtp login name : myemial
smtp login password : mypassword
error :
Not able to send mail to 'This email address is being protected from spambots. You need JavaScript enabled to view it.'.
Contact your administrator.
Can you please support?
Thank you
29 Apr 2015 14:33 #2 by babynus
Replied by babynus on topic Not possible to send E-mail
1) port to SMTP with SSL is 465 (not 464)
2) I thing Google recently change SMTP policy.
Try
smtp server : tls://smtp.gmail.com
smtp port : 587
29 Apr 2015 14:43 #3 by iqbal.ahmed
Hi
same error agian
email of administrator : This email address is being protected from spambots. You need JavaScript enabled to view it.
'from' email when sending mails : This email address is being protected from spambots. You need JavaScript enabled to view it.
'reply to' email when sending mails : This email address is being protected from spambots. You need JavaScript enabled to view it.
name of sender and reply to : Iqbal Ahmed
smtp port : 587
smtp login name : This email address is being protected from spambots. You need JavaScript enabled to view it.
smtp login password : my password
end of line format for mail : default format (\r\n)
sendmail path : blank
Can you please support.
Thank you
29 Apr 2015 16:35 #4 by babynus
What is the error in the log file ?
29 Apr 2015 16:37 #5 by iqbal.ahmed
Hi
How to get log file?
I am not able to locate log file
Thank you
29 Apr 2015 16:38 #6 by babynus
default location in in projeqtor directory, under /files/logs
