ProjeQtOr free project management software - Installation Problems - Page 2 - ProjeQtOr
13 Mar 2015 10:03 #7 by Sterwen
Replied by Sterwen on topic Installation Problems
Pffff.... :angry:
Yesterday evenning, after deleting all table and making a new installation, I just received an error message indicating that there was an error on 2015/03/12 at 22:35.
I thought that it was just a problem of php conf.
This morning, I tried to log with the default parameters admin / admin and then, the error message is "Incorrect connection parameters" :blush:
In the table "resource", I have set the password as "admin" with crypto"null".
I do not know what I should do to solve... :unsure:
If somebody could help, will be great.
Sterwen
"Le progrès ne vaut que quand il est partagé par tous" : merci à ceux qui partagent !
13 Mar 2015 10:07 #8 by Sterwen
The log file indicate that the table pro_user does not exist !
I have verified on my database and this table was not created.... do you know why ?
File Attachment:
File Name: projeqtor_...0313.txt
File Size:17 KB
13 Mar 2015 14:09 #9 by Sterwen
Here the PHP.ini parameters (php 5.5 1and1):
Are those parameters compatible Projeqtor ? Can I modifiy them ?
13 Mar 2015 15:06 #10 by babynus
Replied by babynus on topic Installation Problems
Only constraint I see is max_execution_time : 20 (means 20 seconds).
If config prohibs dynamic update of this parameter (what is tried in ProjeQtOr for installation), your installation will most probably fail.
If so, Only solution for you is to install step by step.
You have two ways :
1) Download each package Vx.0.0 (V1.0.0, V2.0.0, ...) and install them one after one, checking each time upgrade is correct.
2) Download latest version V4.5.6 and upgrade incrementally changing value of $version in /tool/projeqtor.php.
Other strange configuration (really strange for a such well known provider) is upload_max_filesize=40M (correct) with lesser value for post_max_size=8M. You will then never be able to upload file greater than 8M...
13 Mar 2015 15:09 #11 by Sterwen
THanks a lot.
I am not sure to be able to do that, unfortunately. :(
13 Mar 2015 15:16 #12 by Sterwen
Je suis visiblement incapable d'installer.... :S
Je devoir jeter l'éponge et trouver une autre solution de gestion de mes projets.
A tout hasard, auriez-vous une solution logicielle à me proposer ?
Merci de votre aide
